Removing luggage rack on '97 tahoe
Old 02-03-2004, 02:47 PM
bdubc's Avatar
Default Removing luggage rack on '97 tahoe
I want to remove the luggage rack on my tahoe. I know that the outer part comes off with just torx screws, but what do I fill the holes with and how do I get the center part off.
Thanks
Old 02-04-2004, 03:20 AM
LOW2000's Avatar
You would have to get them shaved just like any other part on the truck, they fill the hole, smooth it out and repaint.
Old 02-04-2004, 08:52 AM
bdubc's Avatar
I have seen it where you just pop in little rubber or plastic fillers, and that is the end of it. Perhaps you have to silicone them in but it is a lot less of a pain in the *** than shaving. I was just curious if you guys knew where i could get those fillers.
Old 02-04-2004, 11:42 AM
done that numerous times
Any parts store - or autobody supply
I siliconed them in
Basicaly it is a body,fender plug or fastener.
Better than shaving and painting the roof.
Old 02-04-2004, 12:00 PM
LOW2000's Avatar
Better...no...cheaper...yes
Old 02-04-2004, 01:39 PM
bdubc's Avatar
What about the center pieces of the roof rack??
Old 02-04-2004, 04:48 PM
They are adhesive backed. - Peel off and clean the sheetmetal
Old 02-04-2004, 04:54 PM
My opinion it is better - no welding - dont have to drop the headliner - no filler - no sanding - dont have to paint and clear the roof - retain the factory paint and the rack can be put back on if needed.
Better as far as custom looking - no - nothing better than a good shave
Just have to go for what pleases you and the look your going for.
Old 02-04-2004, 05:53 PM
Registered User
Pro Stock John's Avatar
My police issue 1999 Tahoe did not come with a roof rack:
www.ls1tech.com/99Tahoe/xcar8.jpg
Old 02-05-2004, 01:34 PM
bdubc's Avatar
Can I take the Chrome trim on the fenders off just like the trim on the doors on the tahoe?? Does it just come off with heat??
Quick Reply: Removing luggage rack on '97 tahoe
