Anyone have 400 whp with N/A 6.0L?
13 Second Truck Club
Location: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
1 Post
Originally Posted by Slowverado
when it's done i'll personally mail you one....
How's that aluminum 6.0 block? Is it done to a 6.6 yet? Ok then...
it will probably be hard for you to read since it will go above 240 unlike your's. just let me know and i'll help you figure it out.
Go Slow Go!
Originally Posted by quickWS6
A 5.7 can and has made up to 420-440 rwhp on a pretty regular basis. This is with average to big cams, but with the added cubes of the 6.0, I imagine you could run a fairly stout cam in the truck without too much worry. I don't see it as a problem with a 4L60E. I don't know how much more power the 80E eats up.
Banned
the 4l80e will definatly eat more power than the 60e will...i think i remember parish 8 saying that his 6.0/4l80e felt just about the same as his 4.8/4l60e did it kills that much power. now, once you start throwing heads/cam nitrous, boost etc at it...then it will start to be of more use holding the power better, and you'll have more power to sacrafice.
single digit dreamer
stock 4.8 with just efans was showing low 15's gtech 2.5 60's
stock 6.0 with stall, 4l80e, efans, upd and the best part, thru the full 4.8 single exhaust. low 13's on the gtech, 1.95 60's
i am very happy with the way my truck runs NA, it gets out of the hole great and just keeps pulling.
not sure why but there are alot more nitrous set up's and blower set up's than heads and cam set up's, i dynoed 290rwhp thru an 80 and tcase, i will be going back in a week or so to do another dyno with some tuning and a big cam(but a turbo cam).
Banned
parish, you arogant *******, you must have not read the hole thing where i said I THINK I REMEMBER....honestly it seems like you said that it felt like it pulled about the same. BUT, if you didn't say that then that's fine. but i said i thought you did....hence i wasn't absolutely 100% sure.
1 Post
So how's that built 6.0 coming? Next week right?
