can't remove relay from fuse box
Old 03-14-2005, 06:45 PM
KeukaZ71's Avatar
Default can't remove relay from fuse box
the last 2 times i have changed my fuel filter, i tried pulling the fuel pump relay in the fuse box. but for some reason i can't pull it loose. what am i doing wrong?
Old 03-14-2005, 06:48 PM
Why are you doing that? Seems like an extra step. I just release the pressure from the valve on the fuel rail. Not that much gas comes out and it doesn't hurt anything.
Old 03-14-2005, 06:53 PM
KeukaZ71's Avatar
thanks
i saw that option too in my haynes manual, but i also read on this forum you could pull the relay as well.
i still would like to know how to get the relays out
Old 03-14-2005, 07:37 PM
SnakeOiler's Avatar
You have to pull REALLY hard. Those relays are little buggers to get out. Wiggle it a little while pulling on it. . . . I think I'm starting to get into the offensive
Old 03-14-2005, 08:30 PM
Onyx 02's Avatar
What he said will do it. I used a pair of pliers to get mine out.
Old 03-14-2005, 08:38 PM
KeukaZ71's Avatar
thanks. not sure why it is such a bitch to get out. i pulled pretty hard. i'll try to get a better grip next time
Idryfly5
09-02-2022 08:55 PM
chvy=power
09-08-2015 11:06 AM
LT-1 SS
09-03-2015 07:31 AM
jtphelps289
09-01-2015 09:11 PM
silver-mod-o
07-27-2015 05:24 PM
Quick Reply: can't remove relay from fuse box
