How much tranny fluid does 4L60e hold?
Old 11-20-2005, 11:08 AM
TurboAv's Avatar
Default How much tranny fluid does 4L60e hold?
Dont have my manual anymore. I want to do a drain and refill, as well as replace the tranny filter. How much will I need. Should I go synthetic? I have 70K miles and about 425 crank HP.
Old 11-20-2005, 11:34 AM
wkdivr's Avatar
04 service manual for the 4l60-4l65-E says 5 quarts for pan removal. Complete flush, including converter is approx. 12 quarts.
Old 11-20-2005, 12:24 PM
11 Second Truck Club
bluecajun5.3's Avatar
i've never heard of synthetic for auto trans. just dextron III for these trucks. also wkdivr is correct.
Old 11-20-2005, 01:37 PM
o2man98's Avatar
Here is the info from my manual. As the above states. I would purchase 6 quarts for a filter change to be safe.
CAPACITIES
Engine, with filter..........6.0 quarts
Cooling System, Initial Fill..........16.0 quarts
Automatic Transmission, 4L60E -65E Initial Fill..........5.0 quarts[1]
Automatic Transmission, Total Fill
4 speed 4L60E..........11.0 quarts
4 speed 4L80E..........14.0 quarts
Differential, with 8.25 ring gear Front..........3.4 pints
Differential, with 9.25 ring gear Front..........3.6 pints
Differential, with 8.6 ring gear Rear..........4.2 pints
Differential, with 9.5 ring gear Rear..........5.5 pints
Differential, with 10.5 ring gear Rear..........5.5 pints
Differential, with 11.5 ring gear Rear..........7.6 pints
Transfer Case,..........4.0 pints
Noah Burns
09-13-2015 09:28 AM
screaminian47
09-07-2015 08:20 PM
2004gibbstruck
09-07-2015 06:05 PM
mayko
09-07-2015 12:24 PM
Quick Reply: How much tranny fluid does 4L60e hold?
