Rear Shackle Bolt Removal
Old 03-14-2006, 08:26 AM
FastCrewCab4x4's Avatar
Default Rear Shackle Bolt Removal
Hello All, How do you get the 5"Shackle Bolt out when it's 3" From the Frame?
I want to put drop shackles, all would be easy except for this. Thanks in advance. Great Site!!!!!!
Old 03-14-2006, 08:48 AM
Fogle07's Avatar
if you have a hitch you have to drop it down so you can get the bottom bolt out then you can raise up the leaf springs enough to get the bolt out above the frame. its pretty simple to be honest with you.
Old 03-14-2006, 10:06 AM
virgils4.85spd's Avatar
Default I ground the lip ...
dropping down from the bed out, then i ground part of the bolt flat (the washer part) then pulled it out over the frame..
Derek
Old 03-14-2006, 03:45 PM
slowsierra's Avatar
what Fogle said is the way I did it.I wouldnt suggest cutting anything where its not needed at all.
Old 03-14-2006, 04:24 PM
02BlueStepside's Avatar
Looks like you have a crew cab, if so like fogle said, shouldn't be that hard. Stepsides on the other hand are a little tough.
Old 03-14-2006, 07:09 PM
11 Second Truck Club
bluecajun5.3's Avatar
support the rear of the frame on jackstands to where the rear tires are almost off the ground. next place a jack under the rearend, loosen and take out the bottom bolt on each side(might have to jack the rearend to release the stress on the bolt) slide the bolts out. next jack up the rear end and push the leaf spring up by hand until the upper bolts clear the frame. then you can slide the upper ones out and reverse the procedure...
Old 03-14-2006, 08:44 PM
11 Second Club
ASkipper's Avatar
Look here with pics.
https://www.performancetrucks.net/fo...0&page=1&pp=10
Old 03-14-2006, 11:42 PM
graystepside's Avatar
I had to cut mine because it is a pain in the *** on a stepside.
DarkhorSe_SS
08-20-2015 08:58 AM
LoneSStar
07-27-2015 09:27 PM
signguy62
07-27-2015 03:42 PM
08nali
07-23-2015 11:39 PM
Quick Reply: Rear Shackle Bolt Removal
