How to fix bumper-to-fender gap???
Old 03-17-2006, 11:56 AM
knp01chevy's Avatar
Default How to fix bumper-to-fender gap???
I am wanting to see if anybody has figured out a good way to make the gap smaller between the top of the bumper and the bottom of the fender on the sides??? I have tried to shim it before with no luck, and the gap drives me crazy b/c it looks like the two pieces weren't made to fit w/ each other.....
Old 03-17-2006, 12:20 PM
1badsilver's Avatar
Maybe try re-welding the bumper brackets about 3/4'' higher so the bumper will fit tighter
Old 03-17-2006, 03:46 PM
02BlueStepside's Avatar
I think the people that have done it just use washers to space it up to where they want it. You could reweld the brackets, buts thats a lot of work.
Old 03-17-2006, 06:15 PM
agreif's Avatar
I got this from another thread a little while back: https://www.performancetrucks.net/fo...bumper+bracket
theres an "L" bracket on each side of the bumper if you lay down and look under there. put a jack on that bracket and jack it up little by little until the bumper sits where its suposed to. i had to do that with mine after the fender bender.
Old 03-18-2006, 10:38 AM
JSmith's Avatar
There are side support arms that bolt to the frame and the ends of the bumper. You can loosen those and then take a jack and raise your bumper corners to the desired gap then retighten the support arms. I straightened mine out that way. My bumper used to look like it was tilting backwards.
Old 03-18-2006, 11:56 AM
jagjohn2000's Avatar
wreck your truck and when you put your new bumper on just bend em up lmao. i didn't have it planed that way but i figured i would go ahead sine it was laready liek that. I got mine way upp, touching almost even. but yeah just use a jack, thats what i did.
before:
after:
dsbodley
11-14-2015 09:46 PM
lukn4trbl355
10-21-2015 11:19 PM
SSpeeDEMONSS
10-03-2015 08:21 PM
02AWDAWSDenali
10-01-2015 05:08 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: How to fix bumper-to-fender gap???
