is there a trick to remove the factory clutch fan
Old 03-07-2007, 11:13 PM
javier4.8's Avatar
Default is there a trick to remove the factory clutch fan
how can i remove the factory clutch fan out of my friends 04 gmc truck .
and is there a way to put it back on..
Old 03-07-2007, 11:20 PM
cyazo6's Avatar
They often come of hard with just a wrench. The best way is to have the serpbelt installed on the engine to help hold the water pump pulley from turning. I sometimes use a air hammer with a chisel bit to pound on the nut in the direction to loosen it up. They also make a nice tool that goes in a air hammer with a open end wrench on the other end for easy removal.
Old 03-07-2007, 11:21 PM
TXsilverado's Avatar
i have a long wrench that fits over the nut, and i smack it with a BFH works for me
Old 03-07-2007, 11:23 PM
truckmann's Avatar
Big wrench and BFH.
Old 03-08-2007, 07:22 AM
Lord Aries's Avatar
I used a really BF Pipe Wrnench AND a BFH so that i could feel extra manley!!! The two tools weight more then I do!!! LoL
Old 03-08-2007, 08:14 AM
Hunt&Fisherator
silver-mod-o's Avatar
BIG WRENCH, BIG HAMMER.... rrrraaaahhhhhhh I am man...
Old 03-08-2007, 08:27 AM
HandsomeBWouderful's Avatar
Strap wrench on the water pump, big pipe wrench on the nut. Worked for me.
Old 03-08-2007, 08:28 AM
TOTM: June 2007
bgray's Avatar
Use what there telling you...but if GM corss threaded it on like they did to my clutch fan....Then your gonna need a BFH and a strap wrench. Wedge strap wrench to water pump and dial the basterd off...
And hti the wrnehc towards the passenger side
Old 03-08-2007, 11:56 AM
usmcchevy's Avatar
Another option, go to autozone or advance and borrow a fan clutch removal tool set. Worked great on mine.....once I read the directions
Old 03-08-2007, 01:33 PM
2002C5COUPE's Avatar
I used the removal tool that works w/ an air hammer and i think it took all of 3.5 seconds to get it off
Quick Reply: is there a trick to remove the factory clutch fan
