4wd won't engage - light keeps blinking
Old 08-11-2007, 02:10 PM
High on diesel fumes
thunder550's Avatar
Default 4wd won't engage - light keeps blinking
Having some trouble with 4wd. When I hit any of the buttons besides 2hi, the light just flashes continuously and will never engage. I don't have the "service 4wd" light illuminated on the dash, and otherwise the switch looks like it's acting normal. Any ideas? It's Autotrac, in case that makes a difference.
thunder550 is offline
Old 08-11-2007, 02:16 PM
Grumpy5.3's Avatar
can you pull codes from your transfer case control module??? It sounds like the encoder motor sensor or the shift module...idk
Grumpy5.3 is offline
Old 08-11-2007, 02:18 PM
thunder550's Avatar
I'll get back out there in a minute and see if I can pull any codes. I'm chillin on my American Standard right now
Old 08-11-2007, 02:23 PM
thunder550's Avatar
Nope, no codes in the PCM.
Old 08-11-2007, 02:25 PM
dirtdudeaz's Avatar
Ive had that problem a couple times before without the check 4wd light and a couple with it on. I took it to the dealer and they said they had to reflash the computer, and the other time they replaced a solenoid that went bad.
dirtdudeaz is offline
Old 08-11-2007, 02:26 PM
Grumpy5.3's Avatar
I bet you have some in the transfer case control module. You know anyone with a scan tool that can check those codes???
Old 08-11-2007, 09:10 PM
thunder550's Avatar
Is that different than a normal scan tool? I have EFILive to scan the PCM, not sure if I can get to the t-case module with that?
Old 08-11-2007, 10:22 PM
Grumpy5.3's Avatar
yes its different, you need to find a scan tool that will check the 4x4 system. I bet you have a C0327.
Old 08-13-2007, 03:49 AM
thunder550's Avatar
Question - would low fluid in the front diff cause something like this?
Old 08-13-2007, 09:03 AM
Grumpy5.3's Avatar
Ummmm, its not good, but I doubt it causes your problem. I am betting its your encoder motor sensor... but without pulling codes your kindof in the dark...
Quick Reply: 4wd won't engage - light keeps blinking
