Alternator Wire Mod?
Old 10-22-2007, 08:41 PM
  #71
I'm running a 145amp alt and would like to upgrade the B+ wire from the red junction block to the alt. The thing is, I want it protected (like with a fuse or fusible link), but I want it to look factory. Does anyone know of some thicker guage fusible link that would work? Or a direct replacement that's larger guage?
Old 10-22-2007, 08:44 PM
  #72
TylerCustoms's Avatar
Ive got 4ga with battery connector eyelets soldered and crimped on each end of a foot of scoche amp wire works wonders (ive got a 145a too)
Old 10-22-2007, 09:14 PM
  #73
traveling mod
andrew383's Avatar
jknox- do you have a pic of your setup??
Old 10-23-2007, 08:08 AM
  #74
jknox's Avatar
Not yet - I'll try to take a few in the next couple of days.
One other thing that made it a little easier - when my original battery finally bit the dust in July I bought a yellow-top to replace it. I've got the original factory wires still hooked up to the side posts and the new wiring goes to the tops. Scosche has some battery terminals that accept two 4ga and a single 8ga that Wal-mart sells. I use those for the post connections.
Old 10-29-2007, 09:48 AM
  #75
jknox's Avatar
Ok, here's a pair of pics. Basically what you see here are three ground wires - battery to alternator bracket, alternator bracket to body, and body back to battery.
Then there are two hot lines - alternator to the new mega fuse, and fuse back to battery (which parallels the existing stock wire). I did away with the original wire from the alternator to the red box.
The other cables on the hot post are for the audio setup. Also you can see the 60A maxi-fuse I added to run the efans off of (using the spare maxi location closest to the front of the vehicle.
Does this help any?
Old 10-29-2007, 10:03 AM
  #76
lady3bglover's Avatar
Originally Posted by exhappen
Why do you guys add the wiring in versus replacing it? I want to put a larger guage from the alternator to the red box to the battery. And not have it look like crap.
I agree. Keep the view clean. Just upgrade the wire. I recently too replaced to the 130 from the 105, and I am completely satisfied. I was getting a little more concerned when I knew the reserve in my battery was being compromised.
Old 10-29-2007, 10:29 AM
  #77
jknox's Avatar
Bear in mind that the box cover hides 99% of the crap. I'm also planning on replacing the red battery cables that I originally used with more welding cable. Once that's done the only part that should look non-oem will be the top-post terminals themselves.
Idryfly5
09-02-2022 08:55 PM
ARC
57
02-21-2022 10:54 AM
Cowboy Tom
09-05-2015 04:29 PM
RoidedSS
08-11-2015 11:51 AM
Quick Reply: Alternator Wire Mod?
