Water Pump Leak????
Old 09-17-2007, 08:42 PM
2001si3rr@'s Avatar
Default Water Pump Leak????
I was under my "New to Me" 2001 Z71 today and noted a couple things nothing major I hope, but anyway I thought I would ask.
I noticed a couple of drops of DexCool on the bottom of my water pump, and some small trails were the drops had fallen and worked there way down the front of the oil pan. I almost thought it was some sort of grease because they were not fluid like, they were little red-orange jel like drops. Is it normal for dexcool to jel up or is there something else going on?
Old 09-17-2007, 09:00 PM
If it's coming from the front of the pump or the weep hole (if so equipped), then the pump itself is leaking. If not, it's very common for the gaskets (where the pump mounts to the block) to leak.
Old 09-17-2007, 09:02 PM
adrenalinep's Avatar
If its a small leak and its not overheating its leaking from one of the gaskets. I have replaced the gaskets on my 02 suburban for that reason. My brother had the same problem but his was a smaller leak
Old 09-17-2007, 09:15 PM
2001si3rr@'s Avatar
I think it might be leaking slightly, but have not pin pointed the source of the fluid yet(gasket or weep hole)
So, does dexcool jel up like this if it sits for awhile?
Old 09-17-2007, 09:31 PM
terravast4's Avatar
My 05 had the same problem. I noticed the "jelly" in a crevice in the passenger cylinder head rarely did I see coolant on the ground it took about 6 mos. to figure out it was the gasket leaking.
Old 09-18-2007, 09:54 AM
Yogi Bear's Avatar
Yes, DexCool will gell when exposed to heat and air. That's why it so important to keep the level up in the reservoir tank. If the tank goes dry, and you get air in the coolant in the motor, it will gell there too. You need to find the source of the leak and fix it.
Old 09-18-2007, 05:46 PM
2001si3rr@'s Avatar
Sounds good... Thanks for the help guys..
Old 09-20-2007, 08:25 PM
2001si3rr@'s Avatar
Took the shroud and clutch fan off today, and found a good amount of fluid coming from the weep hole. So, I drained the cooling system and removed and replaced the pump with a new unit from NAPA. Also replaced the thermostat to be on the safe side, then replaced all the old DexCool with new pure DexCool and distilled water. Got everything back together and running good. Funny thing is I think my a/c gets colder now???
Old 09-21-2007, 08:28 AM
Yogi Bear's Avatar
Sounds like you got it. Glad to hear it!
creekrat
09-10-2015 12:59 AM
custm2500
09-08-2015 05:53 PM
slowswb
09-05-2015 02:27 PM
the owl
09-04-2015 04:09 PM
mr03silverado
09-02-2015 11:43 PM
Quick Reply: Water Pump Leak????
