turbo 4.2L trailblazer engine
Old 02-08-2008, 08:39 PM
Default turbo 4.2L trailblazer engine
I have been doing some research on trying to find any performance parts for the 4.2L trailblazer I6. I am doing a swap of this engine into an old F-body and want to do a nice turbo build (sorta like a supra, but better cuz its a bowtie). Does anyone know of aftermarket companies or forums on the 4.2L?
Thanks
Old 02-08-2008, 08:47 PM
Bill Reid's Avatar
History shows the I6 is VERY capable... but location of performance parts is spotty. Not much talked about here.
I know of a twin turbo I6 Trailblazer... that was an EARLY prelude to the SS. Not much was offered to the internals of the motor that I recall.
I have also heard a bracket racer(?) running an I6 in a station wagon (?)...
God... what ever you do please share... I got an 03 Trailblazer my wife is driving right now... I wouldn't mind playing with it after she gets a new ride.
Bill
Old 02-08-2008, 08:58 PM
Bill Reid's Avatar
here is some info Yahoo provided on the TT Trailblazer...
Source: MOTOR TREND MARCH 2002
CHEVROLET TRAILBLAZER TWIN-TURBO
GM's 400-hp sport/utility concept hits 60 in 5.35 sec.
Could it challenge the premium performance SUVs from BMW, Mercedes AMG, and Porsche?
by Jack Keebler • photography by David Freers
NOT SINCE THE LEGENDARY BUICK REGAL GNX, GMC SYCLONE, OR EVEN THE GMC TYPHOON has a similarly quick, turbocharged American product existed. Unfortunately, Chevrolet's TrailBlazerTwin- Turbo exists only as a concept vehicle, and we can't give you an on-sale date. Yet. What we can offer is a behind-the-wheel view with a fully instrumented track test of this 400-hp engineering study. And we can report that this agile TrailBlazer and its twin-blown Vortec 4200 engine are being evaluated for production. GM is a very different place nowadays from what it was even a year ago. Top management has been shaken up, and there are many new faces on deck, aiming to revitalize this sleepy giant. One such is
Ron Kociba, GM Powertrain's chief engineer on the 4.2L inline-six. At Mid-Size Truck, there's another batch of engineers and techs that have the same goals under vehicle- line executive Tom Wallace. Ask Fritz Indra, Powertrain's executive director of advanced engineering, why 400 horses are being extracted from a truck engine that makes 270 in production form, and he makes it sound like a logical extension of everyday engine-development work. "We just think 400 is a nice, reasonable number," he deadpans with his Austrian physics professor's accent. "And we were going after significantly more performance without changing the engine to a V-8.”
"Of course, if we needed more, there's more to be had," adds a smiling, but equally dry Kociba. "The point was to demonstrate the bullet-proof nature of this engine with fairly minor modifications."
We were surprised to learn how little is changed to create this Bullitt Mustang-performance-equaling six, with its twin Aerodyne turbos and air-to-water intercooler. For example, the block, crank, head, head gasket, cams, and valve sizes remain virtually untouched. The extra breathing hardware adds but 45 Ib to the engine's mass. The only critical mods were a switch to 8.5:1 pistons (from 10.1:1), the addition of piston-cooling oil squirters, shorter (by 2 mm) connecting rods, thicker piston pins, higher-flow oil pump and fuel injectors, and a freer-flowing exhaust system. As you'd expect, the 4L60-E four-speed transmission's internals required some beefing, and the transfer case was swapped for the ultra-tough
all-wheel-drive unit found in the 6.0L V-8-powered Cadillac Escalade.
Home office for the 4.2V270-hp Vortec six is the GMT360 platform (Chevrolet TrailBlazer, GMC Envoy, Olds Bravada). So it was logical to install this experimental version in one of those platform variants. The Chevy was chosen primarily because of its mechanical relationship with the hot Chevrolet (GMT368) SSR retro pickup and the long-wheelbase Chevrolet TrailBlazer XL (GMT370) with the third-row seat, both of which will debut soon. Besides, Chevy is the most performance oriented of these three brands.Higher-performance chassis, steering, and brake bits that will be found on the SSR also plug and play in the TrailBlazer, since they share a considerable amount of platform commonality. Mike LeDuc, one of GM's ride and handling development engineers, calls it his "library of parts." So bigger TrailBlazer XL brakes, stiffer springs, revalved shocks, a beefier rear axle, harder track bar and link bushings, and the faster XL steering rack were borrowed from LeDuc's go-fast lending library. Outside, the TrailBlazer (which has been lowered 40 mm) is little modified; keep in mind that this is largely an engineering, not design, project. The roof rack's gone, and functional louvers were punched into the hood. Deep front bucket seats were installed. A boost gauge was popped into the hole left by the 4WD switch. Street-performance-biased 295/45ZR18 BFGoodrich Comp T/As are wrapped around 18x9.5-in. Speedline wheels. The look is buff, but quietly mature; no stripes or wings required. Enough parts talk—how's it work? Running approximately 8.5 Ib of boost, the twin-turbo 4.2 has given up none of its normal smoothness and quiet. Except for that unexpectedly quick climb made by the speedo needle, some turbo whoosh, and a bit of rear squat at launch, things inside during acceleration runs remain quite unremarkable. With the all-wheel-drive system to maximize grip, there's virtually none of the tire slip, yaw, or torque steer of typical high performance machines. This development vehicle's benign overall behavior strongly reminds us of the old turbo V-6 GMC Typhoon/Syclone. Indeed, a postrun look at our laptop revealed a steep acceleration curve and consistent mid-5-sec runs to 60 mph, with a best run of 5.35. That's compared to 8.2 for the standard TrailBlazer. Somewhat disappointing, but probably wise, is a software
bug intentionally left in the engine's computer that limits top speed to 110 mph. Otherwise, no letdowns. The handling/braking upgrades are nicely matched to the newfound power. For example, the beefier brakes and more aggressive rolling stock shortened the production TrailBlazer's 132-ft 60-0 stopping distance by 12 ft. These improvements also conspire to add an impressive 5 mph to the TrailBlazer's pass through the high-speed slalom and helped generate 0.86 g on the skidpad. These numbers put it squarely in BMW X5 territory. Handling at high speeds is largely neutral with initial push and tail-out available under full throttle. Overall, we'd say it's a smart chassis setup by LeDuc and company and a nice complement to the 400 horses underhood. Want one? Send your cards and letters to GM. Though many have wondered about the marketplace viability of highperformance sport/utilities, the demand appears to be there: Last year, the ML55 AMG was the best-selling among all AMG-ified Mercedes-Benzes. BMW is just now coming to market with its own hi-po, though not M-badged, X5. Let's not forget the upcoming Porsche Cayenne. So, why not a 400-hp TrailBlazer.
Old 02-10-2008, 11:42 AM
thunderwagen's Avatar
I think Trick was looking for a test vehicle for the I6 you might get with Rick and see what you can make happen.
Old 02-10-2008, 12:56 PM
kbracing96's Avatar
If I remember right, these was a Chevy II Nova wagon that Parish was racing against in the very first drag week (that they caught cheating, lol) It had that I6 and a big turbo. Might see what you can find on the car...
Old 02-10-2008, 02:45 PM
Tootall's Avatar
Old 02-10-2008, 05:32 PM
adam1803's Avatar
I looked into it before briefly for my wifes TB, couldn't find much info on it. I did hear about a guy with a porsche that had a turbo 4.2 in it but my research came up empty.
Old 02-10-2008, 06:04 PM
ME Performance's Avatar
check out trailvoy.com... there's a guy on their called trav, he's into building custom turbo kits for nissan, but took the I6 trailbazer in as a project... lots of money spent, lots of problems encountered... the turbo kit was installed and is running on the car but with a lot of problems... if it's an 07+ trailblazer u might be able to get away with the tuning as they use the same pcms as the GENIV motors...otherwise expect a "limp" mode after hitting boost!
He had created custom internals for it, everything for the kit was made custom.. it did look pretty decent though!
Old 02-10-2008, 07:08 PM
Truck Sponsor
TrickTurbo's Avatar
Correct we still are.
Old 02-10-2008, 07:32 PM
yurs78's Avatar
Crazy, I've been thinking the same stuff about my wife's envoy. I'm really impressed with the I6, love the smooth off idle torque. Most importantly you can make some pretty good power and still get some great fuel economy. It's hard to get it below high teens for combinded driving, even in winter. Wish my truck would do that
Anyone else know of any more info/help with these vehicles?
Quick Reply: turbo 4.2L trailblazer engine
