Trouble codes po106,171 and 174
Old 04-22-2008, 07:21 PM
2000 SILVERADO's Avatar
Default Trouble codes po106,171 and 174
About 2 days ago my engine check light came on, so I went to autozone so they could see what codes it's showing. It said po106 which means the MAP sensor isn't performing right and codes po171 and po174 which means both the left on right banks are running lean. Could my injectors be clogged up or something? And I don't know what to do about the MAP sensor, please help.
Old 04-22-2008, 07:35 PM
lowsierra's Avatar
I would say the bad MAP might cause your lean condition, I would start there.
Old 04-22-2008, 08:47 PM
13 Second Truck Club
bigbadwolf54's Avatar
I'd venture out and guess that your intake gaskets are leaking and causing the codes....try spraying some carb cleaner type chemical around the base of the intake while its idling, if you notice a stumble you've found the problem, but keep in mind that doesnt always find the leak on the back-side of the gasket. Without seeing the actual freeze-frame failure data intake gaskets would be my first guess.
Pimpinpete
43
12-22-2017 08:13 AM
00loudchevy
12-03-2015 05:54 PM
Avalanche2002
11-30-2015 07:31 AM
bearden86
26
11-15-2015 03:58 PM
kmcn47
09-17-2015 01:12 AM
Quick Reply: Trouble codes po106,171 and 174
