DTC C0550 "Electronic Control Unit (ECU) Performance
Old 01-24-2009, 10:02 PM
lq9crew's Avatar
Default DTC C0550 "Electronic Control Unit (ECU) Performance
C0550 "Electronic Control Unit (ECU) Performance" MH ($29) "Electronic Brake Control Module (EBCM)"
"Service braking system" message on the DIC, abs + brake lights on the dash. PCM went reduced power, only 40% throttle per EFI. Never saw this code or message/lights before, but truck has gone REP before with no codes set. First time I got to scan it.
Dealer? Warranty up in 5k miles. Have stock pcm for this. Code reset immediately after clearing and restarting. SO it should do the same if I swap to factory pcm? I want the dealer to see this code if they will fix it.
Any idea's?
Old 01-24-2009, 10:28 PM
Where's the Beef?
viciousknid's Avatar
Anything imparticular trigger it or did it just show up?
Old 01-24-2009, 10:46 PM
lq9crew's Avatar
The lights and message out the blue. Truck has gone into reduced power before with no codes.
Truck running strong now, code present again after clearing.
Thanks.
Old 01-24-2009, 10:48 PM
Where's the Beef?
I've gotten service Brake System out of the blue before. I was thinking it was because of the cam not giving enough vacuum.
Not sure tho. Hopefully someone knows.
Old 01-25-2009, 03:04 PM
lq9crew's Avatar
This needs to be moved to the GM Board.
I don't know what happened.
Old 01-28-2009, 07:30 PM
bigred06's Avatar
c0550 ebcm malfunction not in your pcm, your ebcm brake module needs to be replaced
internal malfunction
Old 06-22-2018, 10:07 AM
Registered User
Kmarie26's Avatar
i have a 2009 buick lucerne cxl and i recently got a ABS notification on my dash along with a little whining noise i popped a code reader on it and it gave me a code of C0550 could anyone tell me what this is and what to do from here please
thunder550
10-08-2015 04:53 PM
Ketis
07-23-2015 12:37 PM
cbhedrick
07-20-2015 10:12 PM
04BlackGmc
07-16-2015 04:10 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: DTC C0550 "Electronic Control Unit (ECU) Performance
