92 305/350 - setting the timing ? - How to ?
Old 11-17-2009, 12:17 PM
Tootall's Avatar
Default 92 305/350 - setting the timing ? - How to ?
so how is it done? My co-worker is talking about a primary wire that goes to the PCM that needs to be unplugged or something while it's being set?
How do you start? Timing light, and set to 0* and TDC, then what ?
Old 11-17-2009, 03:32 PM
Tootall's Avatar
wow that sounds easy . . .
This is a bone stock truck
Old 11-18-2009, 04:13 PM
blklime02's Avatar
would this work on a 90 model??? im swaping the distributer cap and rotor and was told that i needed to redo the timing......????
Old 11-18-2009, 04:32 PM
454navyss's Avatar
same thing works on a 90 model too
be sure to take mods into account, this didnt work well on my 454ss. i had to keep my timing at 12-14 with the advance unhooked (mods are in my sig) but for a stock engine 0 will work fine
Old 11-18-2009, 04:48 PM
blklime02's Avatar
oh its stock...just a K&N filter...but wat if i later upgrade...have plans for headers and full exaust and chip......
Old 11-18-2009, 04:51 PM
454navyss's Avatar
just bump your timing up a few degrees and see where it runs the best is what i did, some people know how to figure that stuff out but i dont
Old 11-18-2009, 06:27 PM
You don't need to touch the timing to do a cap and rotor, but you can play around with it if you wanted to try and squeak a few more degrees out and see if you pick up any power
Old 11-18-2009, 09:56 PM
blklime02's Avatar
hell yea i wana get some more ponys from it!!! lol
but i go up on the degrees right?
Old 11-18-2009, 10:51 PM
Yes, I'd try going up 2 degrees at a time until it pings then back it off...
Old 11-18-2009, 11:09 PM
blklime02's Avatar
until it pings??
ive never done this befor wat is supose to ping?
wat is TOO much timing??
Quick Reply: 92 305/350 - setting the timing ? - How to ?
