flippping upper control arm
Old 04-12-2010, 02:58 AM
Most Hated's Avatar
Default flippping upper control arm
is it true i can flip my stock upper control arm to get Allignment
Old 04-12-2010, 07:17 AM
slamdlsx's Avatar
yes sir
Old 04-12-2010, 11:17 AM
Most Hated's Avatar
how do i take off the bolt the bolts on to the spindle
Old 04-12-2010, 11:44 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Could you elaborate please?
Old 04-12-2010, 11:49 AM
Most Hated's Avatar
x2.......
Old 04-12-2010, 02:20 PM
slamdlsx's Avatar
By pulling the arm and re installing the ball joint opposite ways. It puts your arm in this position (on the bottom in the pic) fixing the horrid ball joint angles thus making the truck much easier to align and work with and saves ball joints.
Old 04-12-2010, 02:31 PM
Cook's Avatar
im guessing you mean the balljoint bolt? just remove the cotter pin and castle nut then hit the side of the spindle until it seperates.
when re-installing the balljoints, make sure its swinging in the correct motion. there's typically a dot that indicates the front/back
Old 04-12-2010, 03:43 PM
dlt76028's Avatar
Nice! I didn't know this.. You having problems getting your truck aligned?
Old 04-12-2010, 06:56 PM
Interesting, I never considered this possibility. So, do the control arms stay on the same sides, or do you swap left to right, etc?
Old 04-12-2010, 09:33 PM
Cook's Avatar
u take the left side and flip it upside down and mount on the right side, and vise versa
Quick Reply: flippping upper control arm
