Anyone ever got a P0507 code after cleaning throttle body?
Cleaned the throttle body on a 07 Tahoe 5.3 now it gets high idle code and when you rev it up it will idle around 2-3 rpm. If you start it up and don't rev it it will idle at normal rpm but as soon as you rev it it will not come back down to idle. Tried relearning the idle with a tech2 didn't help. Tried a new throttle body same. Smoked the intake showed no sign of a vac leak. Fuel trims are normal. The Tahoe is all stock right over 100k. Any help appreciated.
Did you take the air intake off completely or just off the throttle body? If completely, you had to unplug the connector at the MAF, might not be fully reconnected or a pin got bent? Also check the little tube that hooks into to air intake on the left side just before the TB and make sure its connected at both ends.
I have cleaned probably over 1000 GM T/B's and have not had this problem. Usually it's a low idle and it comes up after cleaning. I would look at the desired and actual TPS request. What is the short term fuel trim % ? I would remove the intake boot and make sure the throttle body opens with out binding and recheck for any vacuum leak.
I know I just asked you to recheck everything that your first post said but sometimes easy mistakes are over looked. I have learned the hard way too many times....
