p2761
Old 10-09-2010, 08:34 AM
SmokinHot98's Avatar
Default p2761
what could cause to to get thrown, why TC seems VERY loose to for what its worth.
Threw the code on the way to a wedding, and then the trans was getting pretty hot
Old 10-09-2010, 08:54 AM
I don't have all of the P codes memorized yet lol, what is a P2761?
Old 10-09-2010, 10:46 AM
from what i've found
P2761 = Torque Converter Clutch Pressure Control Solenoid Control Circuit/Open
Old 10-09-2010, 03:58 PM
Mrgoodwrench3's Avatar
Does it feel like the transmission is stuck in 3rd gear? The ignition switch is a common failure for this code.
Old 10-10-2010, 09:26 AM
yea, and its sucking the crap outta my gas.... then again its a modded 6.0, lol.
It bugs me that the RPM's sit so high. 65 sits @2300 cruising and tap the gas it jumps to 2700-2800.
The TC seems to be bouncing out of lock-up to. So how would I go about fixing this?
thanks
Old 10-10-2010, 09:42 AM
thanks
If the problem is what MrGoodwrench3 mentioned, then replacing the ignition switch will solve your issue
Old 10-10-2010, 10:18 AM
ok, I'll try that. Thanks guys, its been one thing after another bt I think this is the last issue.
I put in my tru-cool 40k cooler yesterday and dropped the temps 60-80*, boy was I happy
Old 10-10-2010, 11:54 AM
Very nice, hopefully that will help extend the life of your trans so you have one less thing to worry about
Old 11-01-2010, 04:57 PM
Cook's Avatar
any update?
Old 02-21-2011, 12:09 AM
sorry its been awhile since I've been on here, but not really. The Ignition switch actually crapped out on me totally so i replaced it and the code has stayed there. When it gets warmer out I have to run over all the grounds to make sure they have a good connection, because I have a huge draw in power when running many accessories. Or it could be the battery.... not sure
Quick Reply: p2761
