04 silverado ac problems
Old 10-17-2010, 04:04 PM
blue0453's Avatar
Default 04 silverado ac problems
So the problem is that the ac is acting funny. If the ac is set to cold on both sides if will blow hot on one side and cold on the other are vice versa, what would cause it to do this? Would it be the ac control box on the dash or something else.
Old 10-17-2010, 05:58 PM
Mrgoodwrench3's Avatar
You may need to have the A/C module calibrated.
Old 10-17-2010, 06:19 PM
blue0453's Avatar
the truck hasnt been driven for about a month, so battery was dead, jumped it off and it has been acting like this since. I have had this problem before but it has usally worked its self out.
Old 10-17-2010, 06:38 PM
PathfinderJr's Avatar
What I found when my battery went dead is that they a/c system needed to cycle a bit, ie have the truck run and then turned off, for the a/c/ to establish it's parameters as far as the blend control doors go.
It was really weird when I first reinstalled my battery, cause almost instantly, on cold a/c settings it'd be blowing hot outta both. Then it slowly cured itself by staying on cold for longer and longer after I kept shutting off the truck and turning it back on. Sometimes it'd blow cold on the driver and hot on the passenger or vice versa without any rhyme or reason, but eventually it got to where it'd stay at the desired temp setting.
It seems kinda dumb, but that's the only thing I could think of. Without the constant power supply from the battery, its like the blend actuators forgot what their min and max values were as far as cold and hot blending parameters.
Old 10-17-2010, 06:50 PM
blue0453's Avatar
Cool man thanks, I hope it does work its self out because it is a little agrevating. But anyways thanks for the advice.
05GMC4.8
08-07-2015 09:55 PM
hartinclay
08-03-2015 07:03 PM
Mossyoakglock
07-17-2015 08:30 AM
grantpo
07-15-2015 12:21 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: 04 silverado ac problems
