GM Factory Remote Start ...
Old 04-08-2011, 03:20 PM
CDN SS's Avatar
Default GM Factory Remote Start ...
2010 Silverado ......only runs for 10 minutes ..any one know if that time can be extended via EFI live ??
Old 04-08-2011, 03:22 PM
Three6GMC's Avatar
I dont think so unless you could get into the bcm but i think that would require a Tech II.
Old 04-08-2011, 07:01 PM
bullygoat's Avatar
No, its hard wired in the BCM. You can extend to an extra ten minutes, it's in your owners manual.
Old 04-08-2011, 08:14 PM
CDN SS's Avatar
Really ......... damm, will go out to truck and check the manual out , Thanks
Old 04-08-2011, 08:33 PM
1994Vmax's Avatar
While the truck is still running just press the lock button again and then start. This will extend the timer for 10 more minutes from whatever point it was at on the countdown. Either that or if it times out just do the lock and start sequence again to restart it. You can only restart, or extend time once giving a max of 20 minutes run time on the remote starter.
Old 04-08-2011, 08:34 PM
CDN SS's Avatar
OK ....got excited there for a moment ........yes I realize you can extend it once its started I was hoping to have it set permanently to run 20 min ....like aftermarket ones ......the extend every time is PIA
So not in the pcm but in the BCM .......
Corvette454l88
09-01-2016 01:24 AM
shawn96gmc
05-17-2016 04:15 PM
cams 98 silverado
07-31-2015 07:36 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: GM Factory Remote Start ...
