Midsize & Compact Trucks Suspension | Wheels | Tires | Drivetrain |Engine | Body
cammed 4.3 dyno #
Old 05-04-2011, 09:55 PM
  #31
GM-only's Avatar
thats what it was! really though an intercooled procharger with some worked heads, and a marine intake is soundin really good to me right now. especially with a t56. i just wanna get side ways man!
Old 05-04-2011, 10:00 PM
  #32
reiners88's Avatar
Haha I hear ya. Ill be looking into either some 3.73 or 4.10s for mine and then the marine intake for now. Then take it to Doc and get it tuned
Old 05-04-2011, 10:05 PM
  #33
GM-only's Avatar
i have 3.73s in mine. i like em pretty good but the motor turns some rpm on the highway. kinda why i want that t56. it has definately helped out with my high way speeding habit i had. my tires are only 25.75 inches tall too so. one of my favorite mods was the rear end. 3.73 gears and the true trac.
Old 05-04-2011, 10:07 PM
  #34
reiners88's Avatar
Yea mine won't be as bad I've got 29 inch tall tires. They were a great price so I went w them.
Old 05-05-2011, 04:39 PM
  #35
L$X$10's Avatar
i would be willing to bet you would put down higher numbers on another dyno. i have been to multiple dyno's and have seen the lowest numbers at efi alchemy BUT have seen the quickest 1/4 mile pass with Doc's(efi alchemy) tune
and go ahead and do the rear mount turbo. that way when you pop the 4.3 you will already have the turbo setup for a cheap 5.3 that will give you insane power for that little truck
Old 05-05-2011, 08:57 PM
  #36
GM-only's Avatar
well that makes me feel alittle better about the numbers. it really does feel good. i keep thinkin to myself wow if this is 170 imagine what 230 would feel like. or 270. or a turbo 5.3 that would really get my truck movin.
ive seen your truck a couple times before i think at the rivercity carshow. i wanna say its every 3rd saturday. that sucker is nice. you goin to go this month?
Old 05-05-2011, 09:33 PM
  #37
reiners88's Avatar
That's exactly my reasoning hahaha when the little 4.3 decides its had enough toss in a 5.3 or 6.0 and you got urself a
Old 05-05-2011, 09:34 PM
  #38
reiners88's Avatar
That's exactly my reasoning hahaha when the little 4.3 decides its had enough toss in a 5.3 or 6.0 and you got urself a fast a$$ truck
Old 05-13-2011, 09:16 PM
  #39
L$X$10's Avatar
thanks man...if im town i will try and make, just have to see how things are looking later in the week
Old 09-13-2011, 08:58 PM
  #40
CenTexBiker's Avatar
Default a few words
I don't know if the post is still going but let me give you some information based on experience
1. the bottom end will not hold up to serious modes. you will need a marine crank
2. insure your compression is not over 9.25 if you plan on using a big turbo or serious over driven supercharger
3. if you run a remote turbo, do it as far back as possible and then route your boost pipe on the driver's side. this will allow the air to cool considerably before it reaches the engine compartment
as to the experience I spoke of: I have a 90 full size ext cab chevy with a 383 that I run a remote twin turbo set on. the oil reserve is in the passenger fender just before the rear wheel. I run a pump from there to the turbos with 30 lbs of pressure. after the turbo the oil goes into an oil cooler that runs its on fan
on street tires with the timing retarded 10 degrees, I am currently running in the low 7s.
something to think about
wish you well on your build
Quick Reply: cammed 4.3 dyno #
