2002 silverado 5.3 trouble code p0332 ???
Old 05-22-2011, 05:44 PM
mr 5.3's Avatar
Default 2002 silverado 5.3 trouble code p0332 ???
my trucks enginelight is on took it to autozone and the code i got back is
p0332.truck has 170,000 on the clock but runs like new even with the code.what can be causeing this and what can i do to fix it??? any advise wil be helpful....
Old 05-22-2011, 07:33 PM
Mod with training wheels
smokeshow's Avatar
Probably a knock sensor going bad. They are cheap to replace.
Old 06-02-2011, 04:11 AM
Registered User
CrAzYLoCaL's Avatar
did you wash or degrease your engine recently?
Old 06-03-2011, 04:08 PM
SnakeOiler's Avatar
See if it's still plugged up or a wire gone bad.
Old 06-03-2011, 06:34 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Knock sensor number 2. I believe thats the rear one. You have to pull the intake manifold off and check them. They usually get water In there and they rust and go bad... search the site there is a thread about how to fix it.
Old 06-04-2011, 03:36 AM
Registered User
CrAzYLoCaL's Avatar
this is such an exhausted subject, but heres my 2 pennies
If ya got a lot of excess water on your motor it will gather on the valley cover where the sensors are located and short them out. Knock sensors are nothing more than microphones listening for detonation and adjust timing as necessary...blah
Anything worth doing is worth doing right, right? so replace both sensors and harness, you"ll need intake manifold gaskets too. To fix it, without being patient, will cost you around $200.
It took a month before my sensors started to work again, dont know what your situation is, but more info would be nice.
My LS1 has over 270K on it, knock sensors are still good to go, just sayin...
zo6freak
14
10-18-2015 06:43 PM
B.love18
09-21-2015 08:31 PM
04450r
07-24-2015 01:58 AM
samg430
07-20-2015 10:12 AM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: 2002 silverado 5.3 trouble code p0332 ???
