4.8 turbo dyno numbers
Old 07-30-2011, 03:49 PM
Most Hated's Avatar
Default 4.8 turbo dyno numbers
dyno' d my truck today at xessive, truck made
674rwhp@6442rpm /573 rwtq on boost only tryed spraying 50 shot but turned it off around 5800 rpms cuz it was leaning out truck was peeling off when it was doing the dyno pull so it should be more power than what it read not bad for a stock bottom end 4. 8 litter with some boost i guess we need to upgrade the stock fuel lines to a -8 an line so it can feed the hungry little 4. 8
Old 07-30-2011, 03:52 PM
too slow's Avatar
how much boost was you pushing...and what kinda set up are you running....oh and congrats man
Old 07-30-2011, 04:37 PM
Slowest turbo build ever!
black00chev's Avatar
Also curious on the specs! Ill be happy just to get over 450/450 at the tires when I get my build all done.
Old 07-30-2011, 05:06 PM
foose04's Avatar
Good to know I still got some head room. What fuel you running? Great numbers bud, I'm sure the tq graph looks good if you hit it with a 50 down low. Look forward to seeing the graph and new 1/4 mile times. I'm thinking some 10.5-10.6x
Old 07-30-2011, 05:10 PM
Llaverito's Avatar
Right now its at 18psi, we gotta fix the fueling issues and make some passes on 18psi and the nitrous. Setup is a stock 4.8, stock heads and bolts, 90mm tb with 07+ intake, 220/220 cam transmission is a stock 4l80e on stock converter.
Old 07-30-2011, 05:34 PM
what size turbo?
Old 07-30-2011, 05:38 PM
11 sec. Truck Mod
TIM Z's Avatar
Damn thems sum numbers!
I should have swapped in a 4.8 !
Old 07-30-2011, 05:44 PM
too slow's Avatar
ive herd of stock bottom ends letting go after 10psi just wondering how stock?
Old 07-30-2011, 06:00 PM
foose04's Avatar
When did he go WOT? That graph is not at all what I expected.
Old 07-30-2011, 09:51 PM
9 Second Truck Club
tarinitup's Avatar
Awesome numbers.
Quick Reply: 4.8 turbo dyno numbers
