2008 GMC Sierra 5.3, Misfire Problems
Old 08-18-2011, 06:29 PM
milkman331's Avatar
Default 2008 GMC Sierra 5.3, Misfire Problems
Hey Guys ,
I have an '08 GMC Sierra and noticed it running rough and I cant figure out if its the Coil and or the wire thats giving it a misfire on Cylinder #6, I put in E3 plugs about 1500 miles ago and just recently starting to have the "misfire"
Thanks
Old 08-19-2011, 05:42 PM
Suburbazine's Avatar
the multi-electrode plug is probably the problem. The OE coils do NOT drive multipoint plugs well- I would recommend putting a stock AC Delco in #6 and seeing what happens. If you really want multi-point plugs, you need MSD coils.
Contrary to what Bosch and E3 would lead some to believe, the multipoint plug is not a miracle in a box. You are limited by coil output. The advertisement can state maximum spark power = max engine power/efficiency, but that's a bunch of hoopla on OE coils.
If you really think it's the coil or wire that is the problem, just switch the whole coil and wire to #5.
Old 08-19-2011, 09:03 PM
tallbluslpr's Avatar
E3 plugs blow I burnt a set up in about 3000 miles got a random missfire code at high RPM I fell for the E3 bullshit for about 1 month get them out they are dangerous. when I say burnt Im talking the groud strap was completely gone on cyl. number 8
Old 08-20-2011, 06:39 PM
milkman331's Avatar
I just wanted to let you Guys know that the E3 Plug is the problem in the #6, I replaced the plug and i will put stokers back in. I got them for FREE so its not like I bought them. What would you suggest as far as minor/good performance mods ??? I did a throttle body spacer and Cold Air Intake , exhaust is next and wondering what would be suggested ????
mhorn0817
03-06-2016 08:00 PM
GMCSIERRA5.3
08-07-2015 01:50 AM
gtyler04
07-28-2015 06:21 PM
smit2732
07-19-2015 01:43 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: 2008 GMC Sierra 5.3, Misfire Problems
