GM fluid capacities
Old 03-06-2012, 04:29 PM
nonnieselman's Avatar
Default GM fluid capacities
Found this on All Data.. figured it might would help to save as a sticky?
i
Transmission Fluid
4L60-E
Pan Removal 4.7L (5.0 Qt)
Overhaul 10.6L (11.0 Qt)
4L80-E
Overhaul 12.8L (13.5 Qt)
Pan Removal 7.3L (7.7 Qt)
Allison
Overhaul 12.0L (12.7 Qt)
Fluid and Filter Change 7.0L (7.4 Qt)
Originally Posted by Robert91RS
1/2 Ton
4WD Front Axle 80w-90 #89021671
AWD Front Axle 75w-90 #88900401
Rear Axle 75w-90 #88900401
AWD T-Case Dex3 #12378470 (replaced by Dex6 #88861037)
4WD Auto T-Case Auto-Trac2 #88900402
Originally Posted by smokeshow
Differential Oil Capacity
Front Drive Axle (8.25") 1.43 liters (1.51 quarts)
Front Drive Axle (9.25") 1.73 liters (1.83 quarts)
Rear Drive Axle (8.6") 2.03 liters (2.15 quarts)
Rear Drive Axle (9.5") 2.60 liters (2.75 quarts)
Rear Drive Axle (9.75") 2.84 liters (3.00 quarts)
Rear Drive Axle (10.5") 2.60 liters (2.75 quarts)
Rear Drive Axle (11.5") 3.00 liters (3.17 quarts)
NVG 149-NP3 2.22 Quarts (2.1 Liters)
NVG 246-NP8 2.0 Quarts (1.9 Liters)
NVG 261-NP2 2.0 Quarts (1.9 Liters)
NVG 263-NP1 2.0 Quarts (1.9 Liters)
Old 03-06-2012, 04:30 PM
Manual Transmissions
Transmission Fluid
NV3500 2.0L (2.2 Qt)
NV4500 3.7L (4.0 Qt)
6 Speed (ZF) (RPO ML6) 6.0L (6.3 Qt)
Manual Transmission
5-Speed with Low Gear - RPO MW3
GM Goodwrench Synthetic Manual Transmission Fluid (GM Part No. U.S. 12346190, in Canada 10953477) or equivalent SAE 75W-85 GL-4 gear oil.
5-Speed without Low Gear - RPO MG5
Synchromesh Transmission Fluid (GM Part No. U.S. 12345349, in Canada 10953465).
6-Speed
Castrol TransSynd Synthetic Transmission Fluid approved to Allison Transmission specification TES-295 (GM Part No. U.S. 12378515, in Canada 88900701).
RPO MG5 - Transmission Manual 5-Speed, Getrag, 84mm, 4.00 1st, O/D
RPO MW3 - Transmission Manual 5-Speed, NVG, 109mm, 5.61 1st, O/D
Old 03-06-2012, 04:33 PM
COOLING SYSTEM CAPACITY
AUTOMATIC WITH FRONT A/C 15.2 quarts (14.4 liters)
With Engine Driven Cooling Fan
AUTOMATIC WITH FRONT A/C 16.8 quarts (15.9 liters)
With Electric Cooling Fan
Old 03-06-2012, 04:35 PM
Refrigerant Charge
Refrigerant Charge 0.7 kg (1.6 lb)
Refrigerant Charge Utility with Front and Rear A/C 1.2 kg (2.7 lb)
Refrigerant Charge Suburban with Front and Rear A/C 1.5 kg (3.0 lb)
REFRIGERANT OIL CAPACITIES
ACCUMULATOR REPLACEMENT
NOTE: Add 60 ml (2 oz) of PAG oil, plus the equal amount of oil drained from the accumulator.
COMPRESSOR REPLACEMENT 60 ml (2.0 oz)
NOTE: The Denso replacement compressor is precharged with 237 ml (8.0 oz) of PAG oil.
CONDENSER REPLACEMENT 30 ml (1.0 oz)
EVAPORATOR REPLACEMENT 90 ml (3.0 oz)
NOTE: If more than the specified amount of PAG oil was drained from a component, add the equal amount drained.
TOTAL SYSTEM PAG OIL CAPACITY 210 ml (7.1 oz)
Old 03-06-2012, 04:52 PM
How about some RPO codes
RPO Code List - Standard Duty
The production/process codes provide the description of the Regular Production Options (RPOs). The RPO list is printed on the Service Parts Identification Label.
AE7 - Seat Front Split, Driver, Passenge
AG1 - Adjuster Front Seat Power, Multi-Directional, Driver
AG2 - Adjuster Passenger Seat Power, Multi-Directional
AJ1 - Windows Deep Tint, All Except W/S and DRS
AL0 - Sensor Indicator Inflatable Restraint, Front Passenger/Child Presence Detector
AM7 - Rear Seat Folding
AN3 - Seat Front, Individual, Non-Bucket
AU0 - Lock Control, Remote Entry
AU3 - Lock Control Side Door, Electric
A04 - Windshield Tinted, Less Upper Shadeband
A28 - Window Rear Full Width, Sliding
A31 - Window Power Operated, All Doors
A95 - Seat Front Bucket, High Back, Driver and Passenger Recliner
BAG - Parts Package Export
BA5 - Ornamentation Exterior, Custom
BG9 - Floor Covering, Rubber
BS1 - Insulation Acoustical Package
BW2 - Molding Body Side Deluxe
B30 - Floor Covering, Carpet
B32 - Covering Front Floor Mats, Auxiliary
B33 - Covering Rear Floor Mats, Auxiliary
B4L - Label Price Refer Geographic Chart
B4U - Performance Package Sport
B4V - Performance Package High Output, Engine
B58 - Covering Floor Mat, Front and Rear, Carpeted Insert
B71 - Molding, Wheel Opening, Colored
B81 - Molding Body Side - Delete
B85 - Molding, Body Side, Exterior, Bright
CKD - Vehicle Completely Knocked Down
CF5 - Roof Sun, Glass, Sliding, Electric
CJ2 - HVAC System, Air Conditioner Front, Automatic Temperature Control, Auxiliary Temperature Control
CJ3 - HVAC System, Air Conditioner Front, Manual Temperature Control, Auxiliary Temperature Control
C42 - HVAC System Heater, Outside Air, Deluxe
C49 - Defogger Rear Window, Electric
C5H - GVW Rating 6,900 lbs
C5M - GVW Rating 6,100 lbs
C5S - GVW Rating 6,600 lbs
C5U - GVW Rating 6,800 lbs
C5W - GVW Rating 7,000 lbs
C7H - GVW Rating 6,400 lbs (2 900 kg)
DE2 - Mirror, Outside Left and Right, Manual Control, Folding, Color
DF2 - Mirror, Outside Left and Right, Wide Load, Folding, Stainless Steel
DF5 - Mirror, Inside Rearview, Light Sensitive, Compass, Outside Temperature Display
DH6 - Mirror, Inside Front Vanity Left and Right, Sunshade Illumination
DK7 - Console Roof Interior, Custom
DK8 - Console Roof Interior, Deluxe
DL3 - Mirror, Outside Left and Right, Remote Control, Electric, Heated, Power Folding, Turn Signal Indicator, Light Sensitive, Color
DL8 - Mirror, Outside Left and Right, Remote Control, Electric, Heated
DPF - Mirror, Outside Left and Right, Wide Load, Remote Control, Electric, Heated
DT4 - Ashtray Cigarette Lighter
D07 - Console, Front Compartment, Floor, Custom
EVA - Test DVT, EVAP Emission Requirement
EXP - Export
EQ9 - Equipment Underride Protection
E62 - Body Equipment Stepside, Pick-up Box
E63 - Body Equipment Fleetside Pick-up Box
E95 - Cover Tonneau, Rear Compartment
FE9 - Certification Emission, Federal
F60 - Spring Front Heavy Duty
GT4 - Axle Rear 3.73 Ratio
GT5 - Axle Rear 4.10 Ratio
GU5 - Axle Rear 3.23 Ratio
GU6 - Axle Rear 3.42 Ratio
G80 - Axle Positraction Limited Slip
G86 - Axle Limited Slip
HOT - Appearance Package GMC "Hot Truck"
HP2 - Hybrid Propulsion Electric, AHS2
JC4 - Brake Vac Power, Disc/Disc, 7,200 lbs
JF3 - Brake Vacuum Power, 17 Disc/Drum, w/ABS, 7,000 lbs
JF7 - Brake Vacuum Power, 17 Disc/Drum, w/ABS, 6,400 lbs
JH1 - Brake Hydraulic Power, Disc/Disc, 6,400 lbs
KNP - Cooling System Transmission, HD
KUP - Throttle Control Electronic
KC4 - Engine Oil Cooling System
KG3 - Generator 145 Amp
KW1 - Generator 160 Amp
K05 - Heater Engine Block
K34 - Cruise Control, Automatic, Electronic
K47 - Air Cleaner High Capacity
K68 - Generator, 105 Amp
LM7 - Engine Gas, 8 Cylinder, 5.3L, MFI, Iron, GM
LQ9 - Engine Gas, 8 Cylinder, 6.0L, MFI, Iron, GM, HO
LR4 - Engine Gas, 8 Cylinder, 4.8L, MFI, Iron, GM
LU3 - Engine Gas, 6 Cylinder, 4.3L, MFI, V6, 90 Degree
L33 - Engine Gas, 8 Cylinder, 5.3L, SFI, V8, Aluminum, HO, GM
L59 - Engine Flexible Fuel, (Gas/ALC), 8 Cylinder, 5.3L, MFI, V8, GM
MTF - Provisions Fire Extinguisher Mounting
M30 - Transmission Auto 4-Speed, HMD, 4L60-E, Electronic
M32 - Transmission Auto 4-Speed, HMD, 4L60-E, Electronic, HD
M33 - Transmission Auto 4-Speed, HMD, 4L60-E, Electronic, Hybrid
NYS - Steering 4-Wheel
NZZ - Sales Package, Skid Plate, Off-Road Spot
NB8 - Emission Override California System
NC1 - Emission System California, LEV
NC7 - Emission Override Federal System
NE1 - Certification Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs GVW
NF4 - Emission System Clean Fuel Fleet
NF9 - Emission System General, OBD MIL Suppression
NP2 - Transfer Case, Manual Shift Control, 2 Speed
NP3 - Transfer Case All Wheel Drive
NP5 - Steering Wheel, Leather Wrapped
NP8 - Transfer Case Active, 2 Speed, Push Button Control
NT8 - Emission System Federal, Tier 2 A
NT9 - Emission System Federal, Tier 2 Phaseout
NU4 - Emission System California Level 2 Plus
NW7 - Traction Control, Powertrain Management Only
N05 - Lock Control Fuel Filler Cap
N12 - Exhaust System Rear Exit
N93 - Wheel 17 X 7.5, Aluminum
PF4 - Wheel 16 X 7, Aluminum
PF9 - Wheel 16 X 7, Aluminum Cast
PY9 - Wheel 17 X 7.5, Chrome Appearance
P03 - Cover, Wheel Var 3
P25 - Wheel 17 X 7.5, Aluminum, 5-Spoke Premium
P27 - Wheel 17 X 7.5, Aluminum, 6-Spoke Premium
P30 - Wheel 20 X 8.5, Aluminum, Sport
P35 - Wheel 20 X 8.5, Chrome Alloy
P96 - Equipment, Mexican Modified Mandatory Base Equipment
QAN - Tire All P265/70R17-113S BW R/PE ST TL AL2
QAQ - Tire All P265/70R17-113H BW R/PE ST TL AL2
QBL - Tire All P265/70R17-113H BW TL ST OOR
QJM - Tire All P265/70R17-113S WOL R/PE ST TL OOR
QJP - Tire All P265/70R17-113S BW R/PE ST TL OOR
QNF - Tire All P235/75R16-106S BW R/PE ST TL ALS
QNG - Tire All P235/75R16-106S WOL R/PE ST TL ALS
QNK - Tire All P245/75R16-109S BW R/PE ST TL ALS
QNL - Tire All P245/75R16-109S WOL R/PE ST TL ALS
QNM - Tire All P245/70R17-108H BW TL ST ALS
QPO - Tire All P245/70R17-108S WOL TL ST ALS
QPR - Tire All P245/70R17-108S BW TL ST ALS
QSS - Tire All P275/55R20-111S BW TL ST AL2
QVL - Tire All P265/70R17-113S BW R/PE ST TL ALS
QVM - Tire All P265/70R17-113S WOL R/PE ST TL ALS
QE4 - Wheel Spare 16 X 6.5, Aluminum
QF7 - Wheel 17 X 7.5, Aluminum, Deluxe
QR9 - Wheel 20 X 8.5, Aluminum Cast, Chromed, 5 Spokes
QS8 - Wheel 20 X 8.5, Aluminum Cast, Chromed, 7 Spokes
Q4B - GVW Rating 6,200 lbs
SAF - Lock Spare Tire, Hoist Shaft
TRB - Grille Radiator, Body Color
TRW - Provisions Lamp, Roof Mounted
TL1 - Grille Special
TP2 - Battery Auxiliary
TR3 - Grille Radiator, Body Color, w/Chrome Emblem
TZ0 - Transmission Manual 5-Speed, Tremec, 85mm, 3.82 1st, 0.83 5th
TZ3 - Emission System Mexico Level (GMM Calibration Responsible)
T07 - Generator - Delete
T2H - Ornamentation Exterior, Export Unique Requirements
T62 - Lamp System Daytime Running - Delete
T64 - Battery - Delete
T78 - Headlamps Control - Delete
T96 - Fog Lamps, Front
T98 - Stamping Vehicle Identification Number
UB0 - Radio AM/FM Stereo, Seek/Scan, CD, Auto Tone, Data System, Clock, ETR
UB1 - Radio AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, CD, Auto Tone, Data System, Clock, ETR
UC2 - Speedometer Instrument, Kilo and Miles, Kilo Odometer, Positive Bias
UC6 - Radio AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR
UD4 - Alarm Vehicle Speed, 120 km/h
UE1 - Communication System Vehicle, GPS 1
UG1 - Opener Garage Door, Universal
UJ6 - Indicator Low Tire Pressure
UK3 - Accessory Steering Wheel Control
UK6 - Radio Control Rear Seat and Earphone Jacks
UL2 - Frequencies, European
UL4 - Frequencies, South American
UL5 - Radio - Delete
UL8 - Frequencies, Saudi Arabian
UM7 - Radio AM/FM Stereo, Seek/Scan, Clock, ETR
UQ3 - Speaker System, Enhanced Audio
UQ5 - Speaker System 4, Dual Front Door Mounted, Dual Extended Range Quarter Mounted
UQ7 - Speaker System Premium Performance, Enhanced Audio, Bose®
UQ9 - Speaker System - Delete
UY2 - Power and Signal Distribution Power Outlets
U01 - Lamp Five, Roof Marker, Truck
U1S - Player Multiple Compact Disc
U19 - Speedometer Instrument, Kilo and Miles, Kilo Odometer
U2K - Digital Audio System S-Band
U42 - Entertainment Package Rear Seat
VBX - Language Label Arabic
VCG - Provisions International Switch/Control Symbols
VCL - Certification Emission, Clean Fuel Vehicle, Fleet
VPH - Vehicle Preparation Overseas Delivery
VYU - Provisions, Snow Plow Preparation
VB3 - Bumper Rear Step, Chrome, Impact Strip
VC4 - Label Price/Fuel Economy, Puerto Rico and Virgin Islands
VC5 - Label Shipping, Except US, US Possessions, or Japan
VC7 - Label Price/Fuel Economy, Guam
VF1 - Bumper Front Painted, Steel, Primed
VF3 - Bumper Rear Painted, Steel, Primed
VF7 - Bumper Rear Step - Delete
VG3 - Bumper Front Impact Strip
VG8 - Vehicle Label, Notice to Buyer
VJ3 - Label, Plate ECE Approval and Vehicle Identification
VJ7 - Label, Fuel Unleaded Only
VK3 - License Plate, Front Mounting Package
VR4 - Trailer Hitch Weight Distributing Platform
VR6 - Hook Tie-Down Shipping
VT4 - Bumper Front Color Keyed
VT5 - Bumper Rear Color Keyed
VZ2 - Calibration Speedometer A
V22 - Grille Radiator, Chrome
V43 - Bumper, Rear Step, Color
V60 - Vehicle Statement Gulf States Organization, Incomplete Vehicle
V73 - Vehicle Statement, USA/ Canada
V76 - Tow Hook
V78 - Vehicle Statement - Delete
V87 - Vehicle Statement Gulf States Organization
W86 - Equipment: Miscellaneous Equipment for Venezuela (GMV Controlled)
W99 - Equipment: Miscellaneous Equipment for Venezuela (GM Platform Controlled)
X52 - Miscellaneous Equipment for Guam, Puerto Rico/US Virgin Islands
X88 - Market Brand Chevrolet
YE9 - Convenience Package Comfort and Decor Level #3
YF5 - Certification Emission California
Y91 - Merchandised Package Luxury Edition
ZX3 - Chassis Package Manual Select Damping
Z49 - Export Canadian Modification Mandatory Base Equipment
Z5X - Mirror Provisions Arabic Language
Z60 - Chassis Package High Performance
Z71 - Chassis Package Off Road
Z82 - Trailer Provisions Special Equipment, HD
Z83 - Chassis Package Solid Smooth Ride
Z85 - Chassis Package Increased Capacity
Z88 - Market Brand GMC
Old 03-06-2012, 07:06 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Stuck
Old 03-07-2012, 12:27 PM
I cant find the specs on the front and rear diff Capacities..
Old 11-28-2014, 11:20 AM
MadDMax66's Avatar
Thank you
Blwn99x
03-24-2023 11:14 AM
turbo6c3
10-05-2015 06:11 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
fortune46x
09-16-2015 08:18 AM
Quick Reply: GM fluid capacities
