Carbed 5.3, what cam would you reccomend?
Old 09-17-2012, 12:09 PM
operatorfailure's Avatar
Default Carbed 5.3, what cam would you reccomend?
It's going in a 3100 pound nova, th350 3500 converter, 4.11 rear car. He wants it na right now but he is a nitrous junkie so getting a cam that would work well with a 150 shot or so would be a good idea. I found plenty of cams people are running in trucks but I don't know how much difference the weight will make. Any ideas? Oh, and he is just wanting to swap cam and springs if possible.
Old 09-17-2012, 01:18 PM
TXsilverado's Avatar
LS1tech has a carb section that has alot of information. it really depends on which intake manifold he plans to run.
Old 09-17-2012, 01:48 PM
Gotcha. I will check out over there. I have never been a carb guy so I don't know what differences it makes on cam choice. Usually responses over here are more on topic and helpful than ls1tech, lol.
Old 09-17-2012, 01:54 PM
very true. it's always easiest to just pay someone to come up with a custom spec. Howards cam has alot of off the shelf LS camshafts that just happen to look like good grinds for a single plane intake. what intake is he running?
Old 09-17-2012, 01:58 PM
He hasn't bought one yet, i just convinced him to go ls over a sbc.
Old 09-17-2012, 05:28 PM
He said he is planning on buying the victor intake. I asked if it was the super victor or victor Jr, or what. He didn't know, just said a single plane.
Old 09-17-2012, 09:20 PM
vic jr for a 5.3. what does he plan to do with the truck?
Old 09-18-2012, 04:25 AM
It's a nova, but street/strip kinda car. More strip than anything but still wants to be able to take it out and cruise when he wants.
Old 11-05-2012, 06:02 PM
Lazered98's Avatar
Tell him to call Geoff at EPS and get him to spec a custom ground cam. I know a lot of guys around here use him.
Old 11-06-2012, 05:20 AM
low2001gmc's Avatar
carbed ls combos tend to respond better to cams with an lsa in the 110 range. since he will be running a 3500 stall and 4.11s with a th350, i would say a cam in the 220-224 range would be best. as for swapping just cam and springs, aftermarket hardened pushrods are almost mandatory and best. good luck with the project...should be fun in a 3100 lb nova, rob
JordanH
08-08-2015 07:59 PM
elpyro89
07-28-2015 05:51 PM
steves86ta
07-28-2015 10:21 AM
06 4.8
07-15-2015 07:17 PM
Quick Reply: Carbed 5.3, what cam would you reccomend?
