Anyone's truck not shut off with the key removed?
Old 02-21-2013, 06:20 PM
JoeyGC5's Avatar
Default Anyone's truck not shut off with the key removed?
I don't have my EFILive cable with me so not able to scan codes. I drove through 4 hours of snow blizzard conditions in my 2011 K1500 5.3 truck with no issues when I was driving. I get to the hotel and find the reverse lights are stuck on. I start the truck thinking the gear position switch isn't made all the way, cycle through all the positions with the trans working correctly. Check engine light is on and the reverse lights are still on with the key removed and the truck stays running. I'm in a hotel with 8" of snow, so I pulled the fuel pump fuse and then disconnected the battery.
Anyone have a similar situation happen? I'm flying out in the morning and leaving my truck at the airport so I really don't care what the damn thing does. I've got 34k miles on the truck and have never had an issue with it. I just wish I had my flashscan cable with me. Oh stock tune and no modifications.
Old 02-21-2013, 08:46 PM
??? Does it act normal after disconnecting the battery and hooking it back up.
After that it's time to take it to a dealer and see what kind of codes it has stored. Can literally be anything on these new trucks if I had to guess it's going to be ignition switch and or BCM related.
Old 02-21-2013, 09:10 PM
JCunningham's Avatar
call dealer and have them drive you to the air port then leave truck with dealer. Your truck is trying to save you money
Old 02-21-2013, 09:18 PM
2000chevysilverado's Avatar
Yeah for snow you only got 8'' we got 15'' here sounds like snow got packed in a place it shouldnt and the constant hot wire from batery is making a iginition wire constant hot instead of switched with the key. I had a problem with my efan harness made my truck stay running till it drained fuel in fuel lines. Ended up my power wire was touching my ignition wire and truck wouldnt shut off till ran out of fuel
JoeyGC5's Avatar
I would mess with it but it still snowing here in Omaha, and theres around 6-8" on the ground. I'd think the ign relays were sticking, but the dash and all other functions die with the key turned off and removed. It's strange to me that the reverse lights are always on and the damn thing stays running, like the PCM or BCM were bad. The dealer won't do jack until I can get it there, at least that's what I was told by the local Council Bluffs/Omaha service manager. Worst case, I'll take the hotel shuttle to the airport
Old 02-21-2013, 09:27 PM
I would let it thaw out and dry and see what happens. Easy fix just gotta find it water possibly in a connector
Old 02-22-2013, 01:13 PM
JoeyGC5's Avatar
Well I hooked the battery back up and it started with no issues. Went into the hotel grabbed my bags and trying to restart it acts like the pcm is dead. So it got towed to the closest delearship
Old 02-22-2013, 06:14 PM
Well at least it left you in a decent spot so to speak. Let us know what they find.
Chris
signguy62
09-20-2015 02:05 PM
wrb002
08-31-2015 12:00 PM
signguy62
07-16-2015 05:43 PM
black6spdz
07-16-2015 01:32 AM
GreyChevy
07-07-2015 08:57 PM
Quick Reply: Anyone's truck not shut off with the key removed?
